I have an AVI movie and when i wanted to decompress the audio with Vdub, VDub keeps telling me that he can't decompress the audio cuz the conversion rate is not right for the chosesn compression (none)
Help'd be appreciated
THX!
Results 1 to 10 of 10
Make sure you have the audio codec's, install Nimo...
Audio > full processing mode
Audio > conversion > 44.1Khz
SAVE WAV
or
Audio > Direct stream copy
SAVE WAV
To uncompress later www.goldwave.com + MP3 plug-ins -
i did try that, i do have the nimo codec pack and it doesn't work...
Vdub says: The requested audio compression is not compatible with the imput format. Check the sampling rate and the channel count of the input match those of the requested format."
Oh, and BTW, the AVI is encoded in DIV3. Maybe it doesn't matter but i'm just telling ya... -
Sampling Rate: 48000hz
Compression: Unknown (tag2000)
The decompressor: DivX Mpeg4 3920 LOW -
When it says "Unknown" that usually means you don't have the codec... The Frequency suggests its AC3, the AC3 is included in the Nimo Codec pack, did you install it ?
See also
Vdub AC3
http://www.digital-digest.com/dvd/downloads/virtualdub.html
AC3 filters
http://www.digital-digest.com/dvd/downloads/encoding_plugin.html -
Yes, I'm 100% sure i installed the Codecs. I checked it by reinstalling the nimo codec pack on FULL INSTALL. And it still doesn't seem to work. I really don't get it. This isn't the 1st movie I encode, but that's the first time i see sumtin like this.
Now, i DLL'ed another version of Vdub, Here's wut it says:
"ACM FAILED TO SUGGEST AUDIO DECOMPRESSION FORMAT" -
Since you Installed "All" of the Nimo codec pack, did you get an error with the reg file for divx 5
try www.divx.com or download the "KJ Codec pack" from Kazza
It may even have a audio codec not included in those packs..
Problem with Virtualdub
By pranjev in forum Newbie / General discussionsReplies: 25Last Post: 30th Dec 2011, 13:16 -
A virtualdub problem
By General Mortars in forum ComputerReplies: 4Last Post: 10th Oct 2010, 07:01 -
VirtualDub Problem
By jarko in forum Newbie / General discussionsReplies: 1Last Post: 8th Jan 2010, 13:26 -
VirtualDub problem
By nic3 in forum Video ConversionReplies: 3Last Post: 1st Dec 2009, 14:29 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08
