What exactly is an xvcd, do they play in dvd players and are they better quality than svcd?
XVCD means you made a non compliant VCD, chances are they wont play in your player !!.
You need to test to see if they will play. Normally used to cram 400 minuets onto a 80 minuet disk
No the quality is not as good if you put 2 disks full onto 1.
http://www.vcdhelp.com/xvcd.htmWhat exactly is an xvcd
Maybe, see..... http://www.vcdhelp.com/dvdplayers.phpdo they play in dvd players
Could be given sufficent data rate.are they better quality than svcd?Evil flourishes when good men do nothing.
