When i try to convert some of my avi files to mpeg1 or mpeg2 the sound is way out of sync. I use TMPGEnc and why i try to convert it says "streaming error" or something close to that, but if i save the sound as a wav first on virtual dub it works but the sound is way out of sync. Can this be helped?
Convert the wav you saved with virtualdub to a real wav first with winamp.
Now, is the length of this wav the same as the video? If not try correcting it in virtualdub with the interleaving (use wav as audio) and save when you have the audio and video correct again. Don't compress the audio and set the video to direct stream copy. You shouldn now be able to get a good sync.
If the length of the wav is the same as the video then just use the wav as source for the audio.
Sound and video do not sync up when I convert avi to h.264 x 264.
By toddlava1 in forum ffmpegX general discussionReplies: 1Last Post: 8th Mar 2012, 03:15 -
More audio sync problems (MPEG2)
By mahonni in forum AudioReplies: 41Last Post: 15th Jan 2012, 16:08 -
Out Of Sync sound in mpeg2
By JN in forum Video ConversionReplies: 2Last Post: 20th Nov 2009, 04:52 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
riverpast rm to avi conversion sound out of sync
By princevegetam in forum Video ConversionReplies: 9Last Post: 2nd Jul 2007, 03:45
