  1. I have attempted to use Gordian Knot to rip a DVD to a DivX 5.02 avi. For some reason what I ended up with was an avi file with just the video stream and an mp3 file (obviously with just the audio stream.) Both files play find on their own. However, I am not able to combine them. If it is of any help I have appended the Godian Knot log.
    I have tried using Virtualdub. File -> Open Video File (chose avi file), Video -> Direct Stream Copy. Audio -> Wav audio (chose mp3 file), Audio -> Direct Stream Copy. File -> Save as avi. But I always end up with an avi file with just the video stream.
    Any help on what I am doing wrong would be much appreciated.
    Fred
    06/09/2002 14:25:01: Job "Movie 1" started.
    o Encode WAV -> MP3: D:\dvd\t042 AC3 T01 3_2ch 448Kbps 48KHz.wav
    o DivX5-First Pass: D:\dvd\t042.avs
    o DivX5-Second Pass: D:\dvd\t042.avs
    o Mux Audio.
    End of Job 2 (Movie 1).
    __________________________________________________ __________________________________________________ ___________________
    Gordian Knot 0.26.0.6
    Encoding Job Data:
    Type: EncD5_Both
    Number: 2
    Platform: WinXP (5.1.2600).2
    Files:
    VirtualDubExe: D:\video\GORDIA~1\virtualdub\Virtualdub.exe
    NandubExe: D:\video\GORDIA~1\nandub\Nandub.exe
    AviFinal: D:\dvd\t042_1.avi
    AviMovie: D:\dvd\t042_1_Movie.avi
    AviCredits: D:\dvd\t042_1_Credits.avi
    MovieFS: D:\dvd\t042.avs
    CreditsFS:
    Log : D:\dvd\t042_1.log
    Stats: D:\dvd\t042_1.stats
    Ecf : D:\dvd\t042_1.ecf
    Options:
    Quality/DRF: 0
    CreditsStart: 59
    UseEcf: 1
    CreditsIVTC: 0
    CreditsAppend: 1
    DeleteInterm.: 0
    EnforceBitrate:0
    AntiShit: 0
    Calculator:
    VideoSize: 575385 kbyte.
    Audio1Size: 230535 kbyte.
    Audio2Size: 0 kbyte.
    Overhead: 13279 kbyte.
    AviSize: 819200 kbyte (800 mbyte).
    FilesSize: 0 kbyte.
    TotalSize: 819200 kbyte (800 mbyte).
    Interleaving: vbrmp3
    Bitrate: 559 k(=1000)Bits/s
    Frames: 210782
    FPS: 25.000
    Duration: 2:20:31
    Quality: 0.086 bits/(pixel*frame).
    CompCheck3: 1.793 bits/(pixel*frame).
    CompCheck5: 0.208 bits/(pixel*frame).
    DivX5BiDirect: 1
    DivX5GMC: 1
    DivX5QuartPel: 0
    DivX5PsyVis: 0
    Resolution: 704 x 368
    Audio 1:
    mode: wav -> mp3
    sourceFile: D:\dvd\t042 AC3 T01 3_2ch 448Kbps 48KHz.wav
    wavFile: D:\dvd\t042 AC3 T01 3_2ch 448Kbps 48KHz.wav
    mp3File: D:\dvd\t042 AC3 T01 3_2ch 448Kbps 48KHz.mp3
    azid: "-c normal"
    lame: "-h --abr 128"
    delay: 0
    interval: 2
    preload: 500
    mux: 1
    recalc: 1
    deleteWav: 1
    Audio 2:
    none.
    14:25:01: Started Transcoding Audio.
    14:25:01: LAME: Encoding D:\dvd\t042 AC3 T01 3_2ch 448Kbps 48KHz.wav
    Commandline: D:\video\GORDIA~1\lame.exe -h --abr 128 "D:\dvd\t042 AC3 T01 3_2ch 448Kbps 48KHz.wav" "D:\dvd\t042 AC3 T01 3_2ch 448Kbps 48KHz.mp3"
    14:41:39: Finished. Duration: 16 minutes, 38 seconds.
    14:41:39: Deleting Wav-File.
    14:41:39: Successful.
    14:41:39: Audio Done.
    14:41:39: MP3-File-Size is 119161 kb.
    14:41:39: Audio 1, determined: 119161 kb
    14:41:39: Audio 1, calc: 230535 kb
    14:41:39: New Bitrate for Movie = 668 k(=1000)Bits/s
    Adding this script to D:\video\GORDIA~1\virtualdub\VirtualDub.jobs:
    // $job "DivX4 First Pass"
    // $input "D:\dvd\t042.avs"
    // $output "D:\dvd\t042_1_Movie.avi"
    // $state 0
    // $start_time 0 0
    // $end_time 0 0
    // $script
    VirtualDub.Open("D:\\dvd\\t042.avs",0,0);
    VirtualDub.audio.SetSource(0);
    VirtualDub.audio.SetMode(0);
    VirtualDub.audio.SetInterleave(1,0,0,0,0);
    VirtualDub.audio.SetClipMode(1,1);
    VirtualDub.audio.SetConversion(0,0,0,0,0);
    VirtualDub.audio.SetVolume();
    VirtualDub.audio.SetCompression();
    VirtualDub.video.SetDepth(24,24);
    VirtualDub.video.SetMode(1);
    VirtualDub.video.SetFrameRate(0,1);
    VirtualDub.video.SetIVTC(0,0,-1,0);
    VirtualDub.video.SetRange(0,0);
    VirtualDub.video.SetCompression(0x78766964,0,10000 ,0);
    VirtualDub.video.SetCompData(328,"GAEAAGAxCgDQBwAA CgAAABQAAAAsAQAADAAAAAIAAAAFAAAAAgAAAJABAAAAAAAAAA AAAB4AAABkAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAA AAAgAAAyAAAAAAAAAAAQAACamZmZmZnJP5qZmZmZmck/QAAAAAEAAACAAAAAAAAAAAAAAAAAAAAAAAAAAIACAADgAQAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOA/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAQ AAAAEAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAA AAEAAAD/////BAAAAEQ6XGR2ZFx0MDQyXzEubG9nAGM6XHRlc3QuZGl2eABEOl xkdmRcdDA0Ml8xLm12AG0=");
    VirtualDub.video.filters.Clear();
    VirtualDub.subset.Delete();
    VirtualDub.SaveAVI("D:\\dvd\\t042_1_Movie.avi");
    VirtualDub.Close();
    // $endjob
    // $done
    14:41:39: Started DivX5-First Pass: D:\dvd\t042.avs
    19:39:58: Finished DivX5-First Pass. Duration: 4 hours, 58 minutes, 18 seconds.
    19:39:58: Trying to open Log-file.
    19:40:04: Success: Log-file open.
    19:40:04: Encoded: 210781 Frames.
    19:40:04: Speed: 11.776 Frames per Second.
    // $job "DivX4 Second Pass"
    // $state 0
    // $start_time 0 0
    // $end_time 0 0
    // $script
    VirtualDub.video.SetCompData(328,"GAEAAGAxCgDQBwAA CgAAABQAAAAsAQAADAAAAAIAAAAFAAAAAwAAAJABAAAAAAAAAA AAAB4AAABkAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAA AAAgAAAyAAAAAAAAAAAQAACamZmZmZnJP5qZmZmZmck/QAAAAAEAAACAAAAAAAAAAAAAAAAAAAAAAAAAAIACAADgAQAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOA/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAQ AAAAEAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAA AAEAAAD/////BAAAAEQ6XGR2ZFx0MDQyXzEubG9nAGM6XHRlc3QuZGl2eABEOl xkdmRcdDA0Ml8xLm12AG0=");
    VirtualDub.Close();
    // $endjob
    // $done
    19:40:04: Started DivX5-Second Pass: D:\dvd\t042.avs
    22:47:45: Finished DivX5-Second Pass. Duration: 3 hours, 7 minutes, 41 seconds.
    22:47:45: Speed: 18.717 Frames per Second.
    Adding this script to D:\video\GORDIA~1\nandub\VirtualDub.jobs:
    // $job "DivX3 Append"
    // $input "D:\dvd\t042_1_Movie.avi"
    // $output "D:\dvd\t042_1.avi"
    // $state 0
    // $start_time 0 0
    // $end_time 0 0
    // $script
    VirtualDub.Open("D:\\dvd\\t042_1_Movie.avi",0,0);
    VirtualDub.audio.SetSource("D:\\dvd\\t042 AC3 T01 3_2ch 448Kbps 48KHz.mp3");
    VirtualDub.audio.SetInterleave(1,500,2,0,0);
    VirtualDub.audio2.SetSource(0);
    VirtualDub.audio2.SetMode(0);
    VirtualDub.audio2.SetInterleave(1,0,0,0,0);
    VirtualDub.audio2.SetClipMode(1,1);
    VirtualDub.audio2.SetConversion(0,0,0,0,0);
    VirtualDub.audio2.SetVolume();
    VirtualDub.audio2.SetCompression();
    VirtualDub.video.SetMode(0);
    VirtualDub.video.SetCompression();
    VirtualDub.SaveAVI("D:\\dvd\\t042_1.avi");
    VirtualDub.Close();
    // $endjob
    // $done
    22:47:45: Started Appending Credits and Muxing Audio.: D:\dvd\t042_1_Movie.avi
    22:49:19: Finished Appending Credits and Muxing Audio.. Duration: 1 minute, 33 seconds.
    22:49:19: Done.
    22:49:19: Movie = D:\dvd\t042_1.avi
    Total Encoding Time: 8 hours, 24 minutes, 18 seconds.
    06/09/2002 22:49:19: Job "Movie 1" finished.
  2. I seem to have fixed it myself using Nanbud. Does anyone know why Gordian Knot didn't work?
    Thanks,
    Fred
