Hi,
I recently posted about my Panasonic player not playing my home-burned VCD's properly. It played them in this slight slow motion. My settings for my VCD's (with TMPGENC) are the following:
MPEG-1 352x240 29.97 fps CBR 1152 kps Non-Interlace Progressive
Layer-2 48000 Hz stereo 192 kbps
Can the Panasonic not handle certain bitrates, like the standard bits per second is 1150 kps for a vcd, but I did 1152 kps. My burning software (Easy CD Creator Deluxe) tells me when it's too high for a VCD, so I thought it'd be okay. Is there any settings for the player that can be adjusted?
A friend tested it on his JVC player and it played fine. My VCD's also play normal on the computer off our DVD-ROM and CD-ROM's.
Any help would be greatly appreciated...
Thanks,
Kristin
Results 1 to 1 of 1
Panasonic XW380 problems
By Skiwi in forum TestReplies: 0Last Post: 20th Apr 2012, 23:19 -
Problems with Panasonic AG-1980
By henryperu77 in forum RestorationReplies: 1Last Post: 10th Jun 2009, 12:54 -
Virtualdub- problems with Motion DV from Panasonic
By avz10 in forum Video ConversionReplies: 2Last Post: 16th Nov 2008, 14:41 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 15:34 -
More Panasonic DMR E85 problems HELP!!!!!!!
By MOTUfan in forum DVD & Blu-ray RecordersReplies: 16Last Post: 20th May 2007, 19:36
