I had ordered this dvd player from ebay and it is supposed to be Macrovision free and Region free when I got it, it was none of the above. After doing some reading I read that the firmare is supposed to be upgraded to do the macrovision, so how do I know if the person i got the dvd player from actually did the firmware upgrade? is there a display button or something that will tell me? if the firmware hasnt been upgraded should i do it myself or actually go through all the trouble of sending it back to the person? Thanx for anyhelp at all. oh yeah i almost forgot it dosnent play dvd-r's.
well if its not hacked and you paid more than $100 then you got burned, Daewoo 5800 are at Sams club for $89 and the hack is avaible for free on the net at
http://www.nerd-out.com/darrenk/
Following his instructions and burn to a CD-R or CD-RW
If you want DVD-R's to play on it after you hack it with the 5800 bios then you must do it again with using the 5700 bios.
Go to this site to find out more about the 5800
http://www.nerd-out.com/forum/viewforum.php?f=29
Good Luck!!
Do the Sony SVO-5800 able to read the PAL tape?
By earth12345 in forum Capturing and VCRReplies: 10Last Post: 30th Dec 2011, 02:14 -
sony vo-5800
By Evgen in forum Capturing and VCRReplies: 11Last Post: 28th Nov 2011, 02:43 -
ATI HD 5800 Series
By fitch.j in forum ComputerReplies: 5Last Post: 19th Sep 2009, 10:25 -
DVD recorder Daewoo DL-3100
By Leonora in forum DVD & Blu-ray RecordersReplies: 0Last Post: 21st Apr 2009, 07:35 -
DVD Daewoo DS-K960U
By TonitoDJ in forum DVD & Blu-ray PlayersReplies: 0Last Post: 6th Oct 2008, 10:08
