I have a FAT32 partition, so I'm splitting AVI captures across a drive in separate files in VirtualDub. When I join them together end to end in iFilmEdit, they work, but it's cutting out frames at the join, almost as if it's performing a rollback on the end of the first clip. Not sure why. Is there another app that joins MPGs better at all?
I use Ulead Video Studio. It seems to load mpegs seamlessly. Although I prefer those awesome transitions it does.
Hello. -
in tmpgenc under mpegtools you can cut and merge (merge works much
better without the crashes), there is a 'how to' guide in the edit section here
Re-create playlist or other way to join .mts seamlessly?
By and in forum Capturing and VCRReplies: 7Last Post: 18th Nov 2011, 12:47 -
Help seamlessly re-combining .mts files without a playlist
By and in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 17th Nov 2011, 13:08 -
Split Files By Size Seamlessly: Possible?
By Threshold in forum EditingReplies: 6Last Post: 18th Jan 2009, 16:06 -
Join several mpgs together
By milway in forum Video ConversionReplies: 2Last Post: 13th Jul 2008, 20:49 -
Quick Question re: Joining mpgs
By boing in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2007, 13:35
