I have a VCD but it is only the .BIN file, it did not come wth a .cue file. I just want to convert it to mpeg format, but VCDGear won't let me because there is no cue file. So do I have to make a cue file, if so how do I go about doing this?
Just load it up as an image file and then check the "burn as raw data" box. Works for me.
Or you can download ISOBUSTER from www.isobuster.com and used that to extract the MPEG from the BIN File.
video file and subtitles file are out of sync because of missing intro
By bmaya in forum SubtitleReplies: 3Last Post: 13th May 2010, 11:26 -
Cue File With Media Player Classic 64
By mugly78643 in forum AudioReplies: 1Last Post: 2nd Jun 2009, 03:42 -
Can you burn a CD-extra using .cue file?
By piano632 in forum AudioReplies: 3Last Post: 15th Feb 2009, 21:45 -
Missing a .VOB file?
By Ego Tripper in forum Newbie / General discussionsReplies: 5Last Post: 2nd Feb 2008, 16:02 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40
