    Adelaide
    hi,
    I created an old avi file in virtualdub and I can not delete it. Says it's in use. The file has been there for months now, it is annoying the shit out of me, any ideas?
  2. pull up a DOS box and try to delete it from there
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
    Nov 2001
    Raleigh, NC
    if a process has a hold of it, I don't know if that will work...
    @wokeupnow- I would end all of the processes you can and then try to delete it.
    End of Line.
