I have just started playing with this app because I have heard it is the only one that can cut VBR MPEG-2 accurately. I don't really need this feature right now...but who knows? Anywho...loaded a few of my CVD samples and encodes-no problem...but...
I recently got my hands on the PAL DVD rips of a certain Speilbergian/Zemekian Sci-Fi trilogy that is still unreleased in the US...but anyway, when I load these PAL SVCD files I get nasty green blocks and M2 Edit Pro telling me I have a VCD file with SVCD header information...and it is otherwise not happy with me...
Has anyone else had a problem with M2 Edit and PAL streams??? I can't belive this is the case...
End of Line.
I don't know about PAL DVD's but I have never been able to use my M2 Edit Pro with MPEG2 files that have fps different than 29.97
use the older version of m2 edit pro ... it accually can handle different bit rates much better ...
but all in all m2 edit is not the most stable (or good) program around for some operations ..
but it does work pretty good for cutting but for joining i generally would end up w/ a corrupted mpeg -
@penamty - well that explains that.
@BJ_M - thanks for the tip.End of Line.
Extreme frustration: PAL to NTSC, using IFO Edit
By gabelogan99 in forum Authoring (DVD)Replies: 4Last Post: 22nd Jan 2011, 14:02 -
DV-Pal to Flv/Wmv-30min edit/target size is 80mb
By stretchweider in forum MacReplies: 1Last Post: 9th Jan 2009, 13:03 -
Rip and Re-edit Question
By dmr1 in forum DVD RippingReplies: 3Last Post: 3rd Sep 2008, 19:00 -
question about magix movie edit
By sd001 in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2007, 03:55 -
PGC Edit Question
By jordanwalkert in forum EditingReplies: 0Last Post: 7th May 2007, 15:10
