I have posted a question related to this once before in a different section, but now I have narrowed the problem down to being My DVD player not My software(at least I think not).![]()
The file plays fine on the PC however after burning I have a audio/video sync problem, which has been as much as 2 to 3 secs out, I tried playing the SVCD on My DVD-Rom (Pioneer DVD-106S) and found that the sync problem wasnt there at all.
This problem is driving Me crazy, as its very irritating, anyone have any ideas that might help Me please? Maybe a real big hammer applied to My DVD player and get Myself another one, lol.
Thanks for Your time![]()
The Hellsing family will purify this world...
it ( from the dvd players list ) appears to be mux and pad sensitive.
VCDeasy was reported to give better sync. I would also try bbMPEG as your muxer ( search for info it's impossible to figure out how to just mux ). I personally find bbMPEG's muxer superior and quicker than TMPGenc.
Good luck -
Thank You Snowmoon,
Ill look around, Im not sure what being Mux and Pad sensitive is but sure its here somewhere on the forum. Also I have tried VCDeasy and can never get it to actually create a valid (S)Vcd.
I have only just started looking at bbMPEG but its good to know its good
Well Im off to get some CD-RW so I can stop throwing away My Single Writes lol, thanks for the help and if anyone has anymore info , Your help would be appreciated
-Edit ~ Thanks Again Snowmoon , I just looked up the DVD Player listing and I think I found the answer to My Problem, I wish I knew this list was here before lol, well Im off to fix My problem up
Laterz...The Hellsing family will purify this world...
Toshiba SD-185EKB DivX Playback
By antmac in forum DVD & Blu-ray PlayersReplies: 6Last Post: 28th Sep 2009, 18:38 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19 -
Problems with Toshiba laptop burner
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 11th Sep 2007, 00:42 -
Toshiba SD-34VBSB disc error on divx playback - any help please!
By Bonnybarbie in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 14:38 -
Does Toshiba HD-A2 play SVCD's?
By desertfox in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Aug 2007, 10:40
