Hello everybody
I'm currently using Linux, and I need help with some MPEG1 files (VCD Pal) I have
The problem is that if i burn them "as it is" with VCDImager the resulting VCD plays perfectly with PC software readers, while on tabletop readers they "skid very often
Under Windows I used to pass them through TMPGenc at maximum precision, and they worked great after that.
Wht programs can I use in place of TMPGenc under Linux? And where can I find them?
Thanks a lot
Closed Thread
Please don't post the same question in more than one forum.
http://www.vcdhelp.com/forum/viewtopic.php?t=111370
Regards.Michael Tam
w: Morsels of Evidence
LINUX: AVI to DVD Encoding and Authoring : BASIC
By disturbed1 in forum User guidesReplies: 13Last Post: 5th Feb 2010, 20:43 -
x264 encoding under LINUX (something similar to MeGUI?)
By graysky in forum LinuxReplies: 3Last Post: 30th Nov 2008, 18:34 -
Linux themed skin for DVD Rebuilder (for Ubuntu and Generic Linux)
By freebird73717 in forum LinuxReplies: 5Last Post: 26th Nov 2008, 20:27 -
How to split a WMV File without re-encoding to another format in linux?
By onesikgypo in forum LinuxReplies: 1Last Post: 22nd Oct 2008, 15:12 -
Nero Linux 3 Delivers Blu-ray and HD DVD Data Burning Support to Linux OS
By BJ_M in forum Latest Video NewsReplies: 0Last Post: 28th May 2007, 10:23
