    May 2002
    Brazil
    I want to know experiences of the others using VirtualDUB -> TMPGEnc.
    The problem is:
    I load a movie (Divx + Wav raw) and start frameserve (ok, why not just put it in TMPG directly? Because I want to insert some subtitles..)
    Well. when the virtualdub are ready to frameserve, i go to TMPG and start the wizard, and make all configurations until i need to browse to file (.vdr, from Vdub).
    When I browse 'n' select it, I get an error ('... file unsupported...').
    Well, it may be a configuration problem, but, when I do the same thing with another video (Divx + raw wav also) it Works!
    the movies (both) load and play in VDub.
    both also play in WMP.
    I try to modify the priority of Vfapi with no results...
    Man this makes me crazy...
    any suggestions?
  2. Maybe non-standard Framerate?
    May 2002
    Brazil
    no...
    its 25 fps...
    curious...
    I get CCE 2.64 and try to encode, but I get the same error (at least like the other error)...
    nothing yet...
    still need help...
    help som'body...
    May 2002
    Brazil
    I forget to say that I use WinXP (also Nimo codec installed)...
    may this be a Codec Issue?
    I get this problem once and try it in other computer with Win2k and works...
    I think I'll make this, but i'm frustrated...
    any one get this prob?
    Apr 2002
    somewhere
    Try scanning for bad frames first,before you use your divx
  6. VirtualDub 1.4.10?
    Frameserver files (auxsetup.exe) broken due to wrong linking to DLL by author.
    Work around:
    Use auxsetup.exe of 1.4.9, you can still edit with 1.4.10.
