  1. I just bought the Pioneer DVR-A04 DVD-R/RW and I have a newbie question. In Device Manager under WinXP Pro, it asks me to select a region that this device is in now and that at anytime I can change the region if I should happen to move to another country but I can only change it a total of 5 times.
    My question is, right now it isn't set to any region. By setting the region to a specific country, do I lose the ability to read DVDs from other countries or make "backups" of movies that i own already that come from other countries? Or is it best just to not select a region?
    Thanks.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    dont select a region untill you have to .. use that firmware link i sent you for region free along with dvdgeni (dvd geni must be used even with region free firmware)
