Hi,
I've got a few DIVX avi's that are FILM 23.976 with AC3.
I can seperate the ac3 no problem.
I can create an MPEG2 DVD video stream @23.976, but spruce up will not accept this framerate.
If I covert to 29.9fps, spruce will take the video, but the resultant video appears juddery - tho in sync.
Is there anyway to author the movie as a 23.976 AC3 DVDr?
Its not the conversion I'm having problems with you understand, its getting something to author it
did you convert it 23.976 with pulldown on playback? with encoder set to 23.976 internal and 29.97 external ?
If you forgot to do pulldown, you can fix the video file using PullDownBatchFE (a GUI front-end for the commandline program pulldown.exe). You will also need to d/l the latest version of pulldown.exe (link in the d/l section of the site above).
AC3 audio: 25 to 23.976 fps
By leghorn in forum AudioReplies: 7Last Post: 14th Mar 2012, 01:36 -
Rip DVD to AVI / Mpeg BUt Retaining File Names?
By tomkat2010 in forum Video ConversionReplies: 1Last Post: 29th Feb 2012, 04:15 -
MKV to AVI - But retaining forced subtitles...
By peejay1977 in forum Video ConversionReplies: 1Last Post: 18th May 2010, 04:00 -
Is SD 720x480 AVC (h264) with 23.976 framerate compatible with Blu Ray?
By hinsdale1 in forum Authoring (Blu-ray)Replies: 17Last Post: 11th Dec 2009, 10:26 -
Burn .avi file to VCD while still retaining subtitles
By Holymoly in forum Video ConversionReplies: 1Last Post: 12th Dec 2007, 21:30
