Hello all. I am using IUVCR on my XP machine to serve as a digital VCR. I've run into problems with audio/vidoe sync. It's pretty bada as the lips don't match the dialogue. When I use AVI_IO to capture the sync is perfect. I would just use AVI_IO but the developer has been unable to get the channel tuning to work with XP's WDM capture drivers.
I'm at a loss. Does anyone know if it's possible to fix this issue? It appears to be a software problem rather than an IRQ/motherboard issue since one application works and another doesn't. Thanks for listening.
What frame rate are you using with IUVCR? I had horrible sync problems with VirtualDub until I realized that NTSC video is 29.97fps not 30fps; I was trying to capture 15fps and my audio was always 0.5sec out of sync; lowering the capture rate to 14.99fps fixed it. If you're trying to capture at 30fps, try changing it to 29.97fps and see if this fixes your sync problem.
CogoSWSDS -
kidfob,
what do you have your audio settings at? When I'm capturing at 29.97fps, I have my audio at 16khz, 16-bit stereo and it works decently...hope this helps..
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
[Audio] Capturing, editing, keeping a/v in sync and dynamic resampling
By rmdeboer82 in forum Capturing and VCRReplies: 1Last Post: 20th Mar 2011, 15:16 -
Capturing with iuVCR
By Lee82 in forum Capturing and VCRReplies: 0Last Post: 2nd Aug 2008, 13:25 -
Capturing In iUVCR
By MosThaTeD in forum Capturing and VCRReplies: 0Last Post: 22nd Dec 2007, 20:15
