  1. i burned a vcd using nero. i encoded it using nero too... but the audio of the vcd plays faster than the video. its not like that when i watch it on the computer. can ani1 help mi?
  2. Did you edit (cut, join, cut) your clip before make VCD? If yes, i ever have the same problem. So I do this trick (i use Ulead Video Editor 6.5):
    - place the clip to time line
    -change the display mode to film strip mode
    - Click the View menu -ruler unit- 1 frame. Now we can see frame by frame the clip in timeline.
    - select clip, right mouse-split the clip, now video & audio is separate
    - select video, cut the first frame, select that frame, copy and paste at beginning clip. Other way, u can insert picture at this beginning frame , as long as the duration is the same with another frame.
    - than at the end of audio clip, insert silent clip to make the same duration with video clip.
    - Render that clip again..burn (i use Nero too) and it's work.
    - I hope this trick solve your problem.
    furqon
