I'm sort of a newbie...burned plenty of VCD's...etc... BUT NOW I have a problem. I'm trying to convert an .exe movie (20 sec cartoon bit "Osama's Last Speech") to avi or mpeg... is this even possible? any helpful hints? I've tried to do some research on this site for the last couple of hours, but haven't found any clues. Help is much appreciated! Thanks in advance!
Well thats an executable file its not a media format so you can't actually convert it to say, mpg or avi.
The only way I think it will be possible is for you to capture it to avi as it plays. Search on the internet for a program called hypercam. Get the demo and follow the instructions. It will basically record anything that is played on your pc screen. Im not positive it will work with an executable file like that but its worth a shot. This will give you an avi file which you can then convert to mpg and burn as a vcd, the qualit y might not be the best though.
Need to create MPEG-4 movie in an AVI container ... how ?
By Bansaw in forum Newbie / General discussionsReplies: 4Last Post: 1st Oct 2010, 15:16 -
TMPGEnc Plus converts AVI to MV2 instead of MPEG movie
By buzzsaw in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2009, 19:36 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 09:42 -
MPLEX.exe only creates HALF the movie.
By supermannnnn in forum Video ConversionReplies: 5Last Post: 19th Aug 2007, 23:45 -
.exe to .avi
By siopawman in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 21:46
