I want to convert an file I ripped from a dvd to an avi using flask mpeg. Flask tells me that this is not an mpeg file. I ripped it using smartripper, with a seperate audio file. Any ideas why it will not accept the file?
I want to make it into an avi and re-encode with cce. Thanks.
The vob files should be accepted, but it depends on which version of FlaskMPEG you are using
Is there a particular reason why you want to use flask? You could alternately use DVD2AVI to frameserve the VOB files to CCE (thru Avisynth). This seems to be the preferred/common approach at the moment.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
