whats the difference ??
why are AVI's alot smaller than MPEGS ??
can you convert to MPEG without loss of quality ???
if you convert to MPEG is the filesize alot larger than the original AVI ?
who was the man that discovered milk, and what was he doing in the first place ??
MPEG is a video compression format devised by the Motion Picture Experts Group and comes in several flavours, but all use the same vasic principles. AVI is a video file wrapper format (Audio Video Interleave and can contain may different types of audio and video data, compressed using one of many different codecs (including uncompressed of course). All you need is the right decoder to play back.
The reason the avi's you have often seem smaller than the equivalent mpeg is that many avi's floating round the internet use compression based on one of the divx codecs. The divx codecs themselves are actually based on the mpeg-4 standard from the same people who brought you mpeg-1 and 2 (as used in (S)VCD and DVD) but in these files the compressed audio and video data streams are stored in the avi file wrapper rather than an mpeg stream. Tthis makes for greater portability and playback on most PC type platforms requires only a suitable codec.
Hope this helps -
There is no difference as far as the name goes, an AVI is a MPEG 4, but a .mpeg could be an MPEG 1Originally Posted by Athlon
Converting from AVI Mpeg 4 to Mpeg 1 is very simple using TMPGEnc, if you have a good quality source AVI, the then conversion will produce a good quality Mpeg 1
MPEG 4, has many codec's associated with it, DivX MPEG 4 being the most popular, it can produce very small AVI's of high quality. However Mpeg 1 does not compress the file as much, if sticking closely to the mpeg 1 VCD spec, It is normal for a DivX MPEG 4 to double in size when converted to a Mpeg 1 for use on a VCD
His name was Adam, while sun bathing in the garden of Eden with Evewho was the man that discovered milk
MPEG-4 ~ what's the difference?
By kr236rk in forum Video Streaming DownloadingReplies: 15Last Post: 3rd Feb 2016, 09:31 -
Whats the difference between these 2 MKV files?
By dave in or in forum Video ConversionReplies: 2Last Post: 11th Aug 2011, 16:44 -
Divx or xvid? Whats the difference?
By szalaikornel in forum Video ConversionReplies: 3Last Post: 17th Jan 2009, 13:16 -
Time difference between VOB and MPEG
By sambat in forum Newbie / General discussionsReplies: 6Last Post: 18th Aug 2008, 16:06 -
SWF mx, swf 3 ( legacy ), and FLV, whats the difference
By theewizard in forum Newbie / General discussionsReplies: 3Last Post: 5th Feb 2008, 00:15
