Anybody know of any other app that burns from CUE & BIN files??? I am using fireburner at the moment and keep getting errors. Not to do with buffer under/over run, but to do with an error in the bin file itself. I am pretty sure that there is nothing wrong with my bin file. Cheers!!
Results 1 to 10 of 10
CDMAGE is pretty good to rewrite the CUE file or also try virtual DAEMON manager which creates an cd drive on your hddrive so u can just play it first without burning to a cdr
Hello pal.
CDRWin (Shareware) works fine, Nero (Shareware) also do it right.
CDRDAO, which is included in VCDEasy (Freeware) also works fine, if your burner is supported.
Take care -
have you guy ever try burnatonce. it's kind of gui for cdrdao. This one great, simply and very small in size. Oh and it's free.
I never had any luck with CDRao...I just couldn't get it to work....my final solution? Use Daemon tools to mount the image as a CD...then use Nero or Clone CD or any other to copy disc to disc....it's fast, easy and works like a charm.
Macros746 -
CDRDAO will work on essentially all modern internal IDE CD-RW burners. All that is required is an adequate ASPI layer (best way to to download and install ForceASPI http://www.vcdhelp.com/tools.htm ).
The next best (probably is the best, but CDRDAO is open source freeware) is CDRWin (the guys that invented the CUE/BIN format). You can get a crippled shareware version (burning limited to 1x or the minimum speed of your burner). This is an excellent program and I suggest you get it. Even you if you do all your CUE/BIN burning with CDRDAO (+ GUI like VCDEasy or XDuplicator), CDRWin is still the best program for extracting existing CDs to a CUE/BIN image (and the demo version does this at full speed).
I strongly suggest you not use a cracked serial number with CDRWin (it is rather devious and will burn coasters).
The newer versions of Nero can burn CUE/BIN files okay.
Blindwrite can do it.
Mounting the CUE/BIN image as a virtual CD with the newer versions of Daemon-Tools and using CloneCD is a good option too if you're desparate.
Regards.Michael Tam
w: Morsels of Evidence -
I used Fireburner in the past but have switched. I now use Blindwrite for writing Bin/CUE files It works really nice and you can get it at www.blindwrite.com
If you deciede to go with CDRwin, do not install CDRWIN 5.0 version. It isn't the same as older excellent CDRWIN. The lastest version of CDRWIN-goldenhawk is 3.9a (3.9a is newer than 4.0a funny, eh?). Before I used CDRWIN all the time for bin/cue files but after I bought a new burner Lite-on 32x12x40 I have a complatible problem with CDRWIN so I change to BurnAtOnce.
If you can't find serial for CDRwin I would suggest you to try BurnAtOnce, here the link h**p://www.burnatonce.com/
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
