Do you need a dvd writer to burn dvds or can you use your cd writer???
You'll need a DVD writer to write DVDs, hence the name.
You dont write books with youir cd writher do you?Well, I am the slime from your video.
Oozin' along on your livin'room floor. -
You will need a DVD-R to burn DVD's; however you can make svcd's with your cdr & there pretty good quality. Cheers Will
You still need a dvd writer
www.vcdhelp.com/dvdwriters.php
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
Verbatim DVD+R DL Disks?
By albloom in forum MacReplies: 12Last Post: 21st Oct 2008, 10:52 -
Is there such a thing as DVD-RW DL disks?
By the_importer in forum DVD & Blu-ray WritersReplies: 8Last Post: 13th Dec 2007, 05:28 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24 -
Toshiba A2 and DVD-R disks
By Prot in forum DVD & Blu-ray PlayersReplies: 4Last Post: 29th Jul 2007, 19:28
