Hello.
I cant get this file to work in TMPG.
"Jurassic.Park.3.DVDRip.SweSub.SVCD.CD2.mpg"
When I try to load it in the TMPG prog. it just says:
File.... can not open, or unsupported.
What can I do to correct this?
Best Regards // Rog.
Best Regards // Roger
calibrie
Try using DVD2AVI to frame serve the file to TMPGEnc. You can find some guides here to explain how to do this: http://www.vcdhelp.com/convert.htm -
www.vcdhelp.com/tmpgenc.htm#problems
read the one about problems open mpg/mpeg2/svcd/dvd.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
changing ifo file names on same file ext of diff dvd files
By holliquinn in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 05:02 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 21:22 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 18:31
