At what reslution should I capture if I want to encode to vcd and svcd by using:
1. KVCDx2-CQ-704x576-(PAL)-PLUS.mcf
2. KVCD-CQ-352x576-(PAL)-PLUS.mcf
3. KVCD-CQ-352x288-(PAL)-PLUS.mcf
4. SKVCD-352x576-(PAL).mcf
please specifiy for each case.
and i capture at 720x576 will it give me the best quality?
i always suggest capture at the highest resolution your system can support and reduce as nessessary .. you will get higher quality ..
others may not agree -
If the target resolution is 352x576, I would capture @ 704x576. I think most resising algorithms work better resising from 704->352 than from 720->352.
general rule of thumb -- if resizing is div by 8 good , div by 16 better ...
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
