  1. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    I've just re-n-coded a a movie using the VCD/SVCD calculator form this site using the DVD option in that to get my Birate.
    I used Tmpegnc 2 pass VBR and the final conversion has ended up at 4.13GB Mpeg 2 NTSC/DVD.
    What i want to know is will this fit onto a Standard 4.7 DVD-r ???
    I suggest that you check this link to find why i had to re-n-code the movie
    http://www.vcdhelp.com/forum/viewtopic.php?t=110834
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    you didnt list the size of the audio file but yes it should fit ..
  3. As long as you use an authoring proggy that does not forcefully re-encode the audio to uncompressed PCM format (which MyDvd does!)
  4. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    Hey guys thx for answering .
    Yes i did give the length of the movie as well as the audio at 384kbps.
    The reason i ask was because if i had used the Project wizard and the DVD template in that i know for a fact that birate would have been far less than what i got when i used the VCD calculator, and the birate i got when i used the calculator, the template would have warned me that it would have fit onto a DVD-r.
