For those who never new![]()
Version : 2.58. 2002/09/03 (03/09/2002)
"ES (Video+Audio)" has been added to stream type in the main window. This mode outputs separate video / audio stream.
"System (Audio only)" has been deleted from the list of stream type in the main window. This feature can be done with "simple de-mulitplex" under MPEG Tools.
Video and Audio stream can be outputted separately if user select DVD template at Project Wizard.
Now TMPGEnc has priority of MPEG-2 decoders at VFAPI plug-in priority setting. The priority is fixed and can not be changed by user as follows: 1:Sony 2:Ligos 3:CyberLink
Bugfix: "Prefetch Video" error occurred if Prefetch Video was enabled at Multi-thread setting
At 1st pass of 2 pass VBR, the character "analyzing" is not clickable anymore(since it does not mean anything).
Bugfix: At MPEG Tools, Merge&Cut, TMPGEnc did not treat MPEG-2 files whose colour_description is "0". (FYI, any version of TMPGEnc produces MPEG-2 file whose colour_description is "1".)
Version : 2.57. 2002/07/19
Stopped reading MPEG-file with "DirectShow Multimedia File Reader", one of the VFAPI Plug-in which is included in the program.
New dedicated VFAPI Plug-in to read MPEG-1 files included. This operates decoder made by MICROSOFT through DirectShow.
New dedicated VFAPI Plug-in to read MPEG-2 files included. This operates decoder through DirectShow if one of the following MPEG-2 decoder is installed.
* CyberLink (Power DVD 4)
* Ligos
* Sony
Results 1 to 1 of 1
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 08:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
