I wrote a .bin svcd file to 4x1 Memorex CDRW's and they play fine in my DVD player. However after writing to the disks I can then no longer erase them using a Mac. I have tried everything but I get these odd errors. I managed to completely erase one using Disk Utility but when I went to use it again it failed . Is this a known issue? This has happed using 6 different disks so either I have a bad batch or something strange is up...
philip
I'm having a similar problem, kind of. I have mastered burning SVCD to cdrw's (Memorex in fact) but once I started trying to include a menu I ran into problems.
With both MisingMenuGen and VCDbuilder, once I build an svcd:
A) DVD player thinks it's a vcd, not svcd, but fails to come up with a menu and fails to play any segments.
B) The mac will display the disc name, and give me a valid get info box, but will not display the files and WILL NOT EJECT!. I can drag it around the screen, try to eject, but it on't go away. Tried to kick it with the finder, and other stuff with no luck. It hangs Toast completely. I have to paper clip eject the disc to getthe sucker out and reboot to regain control.
Never had this touble till I started to put on a menu screen.
Like I daid, I had no problem building scvd's with multiple segments, the disc was fine on the dvd player and the mac. -
Not specifically the Memorex CDRW's but Memorex Cd's in General I have had a problem with in the past. Out of a 20 or 25 pack I got like 4 to burn.
And that was with some tinkering and several showdowns with the Finder!
I called Apple And they said the best CD media to use is either "imation" or "Verbatim". I personally use imation it works in all DVD Players, Cd players, (including car and portable) and pc's that I have tried.
Never used Verbatim though. I have also had excellent results with Teon branded cd's
Not sure about the CDRW on DVD/VCd issue, but Memeorex has given me some problems."First god damn week of winter." --R.J. MacReady -
Just thought i'd give my 2 cents.
I've burned about 150 Memorex CDR's and NEVER had a failure. I've not tried MP3 discs or SVCD's (my player doesn't support it
but I have used them for VCD's
They're cheap and I'm cheerful
I too have no problems with either the 74 minute CDR or CDRW disks from Memorex. It's the 80 minute CDRW's which write once but then never again (:Originally Posted by dwoodusa
Note that there is a way to trick your DVD player into playing SVCD. My Panasonic doesn't support SVCD either but I can fool it. The info is on this site (and there's also a thread called pseudo SVCD's which discusses the issue).
philip
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 06:04 -
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 06:45 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 06:18 -
CDRW Erasing Cancelled - CDRW NOT WORKing
By Sarao in forum ComputerReplies: 6Last Post: 5th Feb 2010, 11:55
