I always use variable bitrate encoding, as I have learned from reading all of you guys' informative posts on this fine forum. My question is, how long would a movie have to be before the majority of you would divide into 3 80 minuted cd-r's instead of 2 80 minute cd-r's. As I stated earlier, I am using vbr encoding to maximize the amount I can fit on 1 cd.
It depends on what kind of content the movie has (how much action, how "busy" the scenes are) since some can be compressed more than others without unacceptable quality loss. It also depends on what you find to be acceptable. Personally, I find that it's best not to put more than about an hour on a CD, but for things that don't have too much action I've put as much as 80 minutes on one CD without any bad artifacting. And some people don't like to put more than about 45 minutes on a CD.
I think the answer depends on the individual, the type of movie, whether it's widescreen or fullscreen. Personally I find most movies that are 2 hours or less will fit nicely on 2 80min CD's with good quality if doing 4-pass VBR. Anything more then 2 hours I'd consider using another CD. This will depend on the type of movie it is, action movies often require more bits to get the same quality as a drama or talking movie. Widescreen movies when letterbox will also be easier to encode because you are basically encoding a 480x360 pixels as oppose to 480x480 (if using SVCD).
-LeeBear -
I use an average of 2350 to 2500kpbs 2pass for xvcd, and usually do 45min per cd. Picture quality is about as good as it gets on a vcd. (very clean, almost completely block free)
Just depends on your likings.
Only convert the first 10 minutes or so ...
By GMUET in forum ffmpegX general discussionReplies: 4Last Post: 8th Jun 2011, 15:13 -
more than 120 minutes on 1 DVD
By icethekicker in forum Authoring (DVD)Replies: 8Last Post: 6th Apr 2011, 17:32 -
Last few minutes of video frozen...
By JohnC1726 in forum RestorationReplies: 3Last Post: 14th Jan 2010, 09:56 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 04:55 -
Video crashes after a few minutes
By Diego123 in forum Software PlayingReplies: 16Last Post: 4th Jan 2008, 11:04
