my computer is really starting to piss me off, it can play .Mpeg and most other formats but when i try to play an .avi it wont it will say that some kind of error occored, so it just plays the sound and not the visual stuff
but it plays .mpeg perfect is there any way i can convert .avi into .mpeg?
Look at that green area in the left column - "how to - convert"
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Sorry that didnt help i couldnt find anything on what i am trying to do
please help! -
Originally Posted by ZeroX
http://nimo.everwicked.com/ http://perso.wanadoo.fr/nimo/ -
Just like mirror_image said: look in the green how to, convert. Try using 'How to convert to VCD(=mpeg) using TMPGenc'.
Works just fine for the rest of us.
Also make sure to install all the right codecs for playing avi. It's best that you install the nimo codec pack(found in the red colum under tools, title codecs). -
Originally Posted by J
No need to get cheeky. You posted your reply just seconds before I posted mine. I didnt mean to repeat you.
MPEG-2 528x576 to AVI conversion problem.
By madman1987 in forum Video ConversionReplies: 7Last Post: 3rd Feb 2009, 10:53 -
Quick .avi Conversion to MPEG-2 ?
By christopheramos in forum Video ConversionReplies: 7Last Post: 5th Feb 2008, 18:42 -
AVI to MPEG conversion and DVD burning
By mc-help in forum Video ConversionReplies: 2Last Post: 5th Jan 2008, 16:08 -
Problems with mpeg after conversion, or with original avi - help
By krisbee in forum LinuxReplies: 1Last Post: 30th Oct 2007, 16:56 -
No sound conversion MPEG-TS to .avi
By oli60 in forum ffmpegX general discussionReplies: 2Last Post: 22nd Oct 2007, 00:49
