Has anyone had problems with their hard drive before? I have mine formatted (a 60 GB) into 4 partitions. I use this rive exclusively for encoding and the letter s are D,E,F,G.
The D partition is getting some bad sectors on it. And has basically rendered itself useless for encoding purposes. Is my hard drive dying?? Can I fix these bad ssectors? I usually encode every night and it takes about 7-10 hrs.
Please help
Run Norton Disk doctor on it, or Windows Scandisk. Sounds like its worn out. Try a re-format if all else fails.
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 15:58
