A lot of the SVCD's that are DVD rips have a great picture but end up sounding very compressed in two different Apex players. The surround and sound effects are great, but the dialogue will have that harsh compression sound that makes my hair stand on end. I'm burning with Nero.
Is it the D/A conversion on the Apex players? Should I try another brand?
Is it the original rip?
Maybe it's your surround sound! When Pro Logic sends the ambient to the rear speakers, not all voice artifacts are removed leaving the "compressed" like voices on the background.
This may or may not be your problem. TMPGEnc 48>44kHz audio downsampling does a miserable job which particularly makes voices on audio tracks sound this way. I use SSRC as an external plug-in to TMPGEnc with Option/Environment Setting/External Tool/Sampling Frequency Convertor/...browse to SSRC.exe. Takes a little extra time to process audio but well worth it. You can get it here:
http://www.afterdawn.com/software/audio_software/audio_tools/ssrc.cfm
Compressed Too Small?
By OutOfBreath in forum Authoring (Blu-ray)Replies: 5Last Post: 4th Nov 2011, 19:41 -
Which is least compressed format?
By vid83 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Dec 2008, 20:59 -
AVI and compressed 5.1
By cyanyde in forum DVD RippingReplies: 13Last Post: 2nd Jun 2008, 16:06 -
compressed capture with composite
By benaw in forum Capturing and VCRReplies: 2Last Post: 20th Nov 2007, 09:09 -
Are pdf files compressed?
By yoda313 in forum ComputerReplies: 2Last Post: 20th Oct 2007, 12:13
