This is a really strange problem that started after I installed CCE SP. I am frameserving an MPEG2 ripped from a DishPVR to CCE via DVD2AVI and Avisynth. Everything works fine up until I start encoding with CCE. Then, after I click "Encode" my computer spontaneously restarts. No error message, no lockup, no warning--just an instant reboot. Sometimes it does it right away, other times it does it 20 minutes or more into the encode.
I thought maybe it was a CPU temperature issue, especially since after CCE started doing it, so did TMPGenc when I tried using that as a Plan B option, so I did some tweaking with my fan positioning, but it's still happening. After messing with my fans, my C: drive died and I had to rebuild my system. Then I discovered the release of the Nvidia drivers I was using had a lot of problems and there was a more recent release of drivers, so I rebuilt again and tried using those. Still no luck; my computer spontaneously rebooted 20 minutes into a 45 minute encode.
Anyone know what could be causing this?
KSJ
Update:
Just gave it another shot. Tried shortening the file name, adding the "ResampleAudio" line in the AVS file, and lowering the average bitrate, in case the bitrate of the original MPEG was lower then what I was trying to encode to. No joy. Got about 17 minutes into the estimated 47 minutes and restarted my computer. Still no error message, warning, or anything else to indicate what the problem might be. The encoding speed hovers in the 0.925 range, give or take .005.
Results 1 to 1 of 1
"Only an idiot fights a war on two fronts. Only the heir to the throne of the kingdom of idiots fights a war on twelve."
--Londo Mollari, B5
Computer keeps shutting off
By black cloud in forum ComputerReplies: 18Last Post: 2nd Aug 2011, 21:54 -
Computer keeps shutting down
By mac71671 in forum ComputerReplies: 8Last Post: 29th Jan 2010, 09:45 -
By didikai in forum Newbie / General discussionsReplies: 22Last Post: 31st Aug 2008, 08:24 -
problem in megui causing SHUTTING DOWN my computer !
By LOST World in forum DVD RippingReplies: 5Last Post: 15th Feb 2008, 04:45 -
Computer keeps shutting down, won't stay on.
By Super Warrior in forum ComputerReplies: 6Last Post: 9th Aug 2007, 15:34
