  1. I am using a template I downloaded from this site. When I go throgh the wizard and select it I cannot edit the slider bar that controls the bitrate and final file size. It is locked - how do I make this screen unlocked. I thought that homemade templates always left this screen unlocked in the wizard. HELP
    thanks - War
  2. There is a template called Unlock that you must load to unlock things. The template is in your template folder allready.
    (Re-reading your question I see that you might have a different question than the one I answered. I'll leave this here just in case it is helpful.)
    Aug 2001
    JERSEY
    i dont think the templates are suposed to be used with the wizard close the wizard then load the template and if it still doesnt unlock try what presto said and load the unlock template in the extra folder
  4. The problem is you cant get to that wonderful window that lets you drag the bar to fit your movie onto your media unless you go through the wizard!! How do I get to this screen?
