Hi; I am new to most of this ; and I am having problems converting a ASF file in the TMPEG converter ; it runs very slow....actually too slow. it would take me 3 weeks just to convert . I have enclosed the file name ....if anyone can help me with this file I will be very gratefull.![]()
File Name: nightwish_300.asf
File Format: Advanced Systems Format (ASF)
Author: Microsoft Corporation
Web Site: www.microsoft.com
Content: Video and Audio
Duration: 1 hr 21 min 11 sec
Data Rate: 308 kbps (ave)
Video Info: 320 x 240
Audio Info: 32000 Hz, 32.0 kbps, stereo
Video Format: Windows Media Video 7
FourCC: "WMV1"
Audio Format: Windows Media Audio
Format ID: 0x0161
Results 1 to 16 of 16
im stupid.....leave me alone.
Originally Posted by crow68x
Also set DirectShow priorities higher.
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
ASF can also be opened in Vdub 1.3C -
were do i install the codec? do I put this in the main folder of TMPEG ?
im stupid.....leave me alone. -
the set-up you gave me didnt work; I installed the codec and changed the settings but it is still running slow....as soon as the video hits were the audio starts it just goes really slow.....as I said it will take me about 3 weeks just to convert this file.......please help me finding a better solution to convert ASF
Will it load into Vdub 1.3C ?
If you use the source range in TMPGEnc and start a few minuets past that section, does it still give problems ?
If its a Bad ASF you may need to use Graphedit to convert to AVI first -
it woulnt even load to the Vdub 1.3C ; unless i set it up wrong.
on TMPGEnc;how do you set the source range....never done that before.im stupid.....leave me alone. -
I think i need to convert this ASF to avi 1st.....is there any good tools that I can use for this? I tried ASFTOAVI and the video came out distorted but the sound was fine....maybe if there is a setting to fix the video. I was thinking maybe if someone could help me with this file ;the name is: mms://wm3.xs4all.nl/paradiso/blokandsteel_300.wmv
and you can use streamboxvcr to save the stream. please help me.im stupid.....leave me alone. -
opps...wrong file; this is the one: mms://wm3.xs4all.nl/paradiso/nightwish_300.wmv
Just rename it to ASF then load into Vdub !!
Ok Its streaming in the background... 01:21 Min long !!! and the server is dam slow 500 Kbps, it it will take a while to save.
OK, I now have 183, 576 of a downloaded file, which I dont know what the heck it isthat will teach me to use a new capture program.
So I started again with the ASFRecorder (Old trusty) and its saving it as "nightwish_300.wmv"will see what this one is
Ok, the ASF Recorder works just fine, paste the url into it, and it asks for the file name (nightwish_300.wmv)
ASF Recorder saved the file to my hard drive in about 15 min, I then loaded it into TMPGEnc, and tested a quick conversion.
No problems.... -
I tried that just now....i converted it using the asfrecorder then I used tmpeg ; it made a 809 mb file wich was kinda distorted from the original and the video and audio did not sync together. i dont know what I am doing wrong.
Is that an Intel CPU ?
Don't know what your problem is, I made an Mpeg 1 out of it, and it was crystal clear and no sound problem. Converted the first 10 minuets using TMPGEnc. When you say you converted it, did you load the url into AsfRecorder to download it, it removes the protection on download.
When you have it on your hard drive, you can rename it to ASF, then some programs will then load it, and react differently. What did you convert the WMV into with TMPGEnc ?. Did you use a template
You could also save out the sound for use later File > Output to file > WAV
Don't know what your problem is, as it works just fine here.
I also did a test in Graphedit, and that also works.
Many of the other WMV to AVI/Mpeg programs will also work, now that you have it downloaded via ASFRecorder
Mpeg capture in Vdub
Ok, did a full conversion from WMV to DivX
AVI with MP3 audio, below is the info for graphedit, I chose the DivX output just incase the raw AVI maybe too big to fit on your hard drive.
Graphedit
1 file Render media file, select "nightwish_300.wmv"
A graph is now drawn
2 delete everything "after" Windows Media "Audio" Decoder
(Click box and press delete)
3, delete everything "after" Windows Media "Video" decoder
This is now the graph
nightwish_300.wmv stream 1 > ASF ACM Handler > Windows Media Audio Decoder >
nightwish_300.wmv stream 2 > ASF ACM Handler > Windows Media Video Decoder >
Ok your now ready to add some more to this graph
4, Graph > Insert Filters >Audio compressors > MP3
5, Graph > Insert Filters >Video Compressors > Mpeg 4 low motion
6, Graph > Insert Filters >DirectShow filers > AVI Mux
7, Graph > Insert Filters >DirectShow filters > file writer
(enter nightwish_300.avi)
Now we will connect the filters
nightwish_300.wmv stream 1 > ASF ACM Handler > Windows Media Audio Decoder > MP3 > AVI MuX (1) > File Writer (1)
nightwish_300.wmv stream 2 > ASF ACM Handler > Windows Media Video Decoder > MP4 Low motion > AVI MuX (2) > File Writer (2)
Just click and drag the output to connect the line to the inputs.
Click Play >>
The conversion will start and you can click stop after a min, and test the output. Click Start again to do the whole lot.
Progress can be shown by right clicking the "AVI MUX" and selecting properties. It should take about 30 min or so, depending on your CPU
Unlike other WMV to AVI that just changes the file type, this conversion does a better job if there are any problems in the source.
I am still lost in this file conversion. in the graphedit program I cant find the 4th part of the instructions on how to do it: 4, Graph > Insert Filters >Audio compressors > MP3
there is no MP3 in the options....I tried other methods in the audio compressor but it didnt work. any suggestions?im stupid.....leave me alone.
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
Can't get it to work???
By rjocon in forum ffmpegX general discussionReplies: 1Last Post: 12th May 2009, 16:00 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 15:35 -
How do they work?
By JamesGT in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Nov 2007, 08:48
