Hi all..
I have a problem, please help me, I'm using LifeView's FlyVideo 2000 as tv tuner and capture card, and I tried to capture a 68 minute video using it with its software (FlyVideo). I set the capture setting to 352 X 240 (NTSC VCD) and the result is good. I capture to .MPG file.
The problem is, the .mpg file size for the 68 minute video is 2,11 GB!
I think the normal size is around 700 MB.
And I cannot split the 2,11 GB file (I'm using VCDCutter). So I reencode the video using TMPGenc, and the result is 706 MB, but the quality of the picture decreases.
Also, the mpg generated by TMPGenc can be cut using VCDCutter.
So, why is the mpg file size of my capture reaches over 2 GB?
And why can't the 2 GB mpg file be cut using VCDCutter?
Results 1 to 1 of 1
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
H.264 output file size too big vs WMV
By bijoythulas in forum Video ConversionReplies: 5Last Post: 29th Sep 2008, 22:21 -
Why does TMPGEnc DVD Author3 say that my file size is too big?
By jimdagys in forum Authoring (DVD)Replies: 4Last Post: 7th May 2008, 20:48 -
Captured audio from .mpg file can't be seen/read by many programs!
By omnikai in forum AudioReplies: 4Last Post: 16th Sep 2007, 15:09 -
Captured File Size Question
By pbmc59 in forum Capturing and VCRReplies: 10Last Post: 6th May 2007, 21:41
