i used dvd2avi to make my d2v project and then i used tmpgenc to make the movie smaller in size now i have a m2v file how do i remix back sound and back to my vobs so i can burn to dvd-r im lost read a lot of the guides and im still lost waht to do next?
Use dvd2avi to demux the audio as well (under Audio...Output method...Demux all tracks). If you leave that option selected, then it will always demux the audio for you whenever you save a project.
This will give you your .ac3 sound file and .m2v video file. Now you can load these into your DVD authoring software and create your DVD. See if you can get a copy of SpruceUp as it is very simple. Just make sure the video and sound file have the same name (i.e. movie.ac3 and movie.m2v) if you are using SpruceUp. Not all authoring software supports AC3 sound, so choose carefully.
TMPGenc 4.0 XPress Question
By spliffy in forum Video ConversionReplies: 1Last Post: 19th Oct 2009, 17:04 -
TmpgEnc 4 XPress Question
By VEBouto in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2009, 19:36 -
TMPGENC question
By triumph2004 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Aug 2008, 23:21 -
TMPGEnc question.
By Hal05154 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 08:20 -
TMPGEnc Question
By dafoe in forum EditingReplies: 5Last Post: 12th Oct 2007, 04:38
