backed up time machine of dual layer dvd , but when played on set toponly 1 hour of film instead of 1 hour 36mins can anyone tell me why plz, the file size was under 4.7 it was 4.2 thanks, ps used dvd decrypter and nero and al the others so many porgrams out there
most probably because you ripped to a single m2v file and are not using NTFS so it doesn't support files over 4GB, most ripping programs report that the rip was successful but cut the end off the movie leaving you with a 3.9gb file.
thanks for the reply how do i over come this, iam not a newbie to pc ,self build installed two drives and two opperating systems,plz advise
Guest
if you are running Win2000/etc convert the drive to a ntfs partition this will allow files bigger that 4gb. But in doing this you will lose all the data on that drive so be sure to back up any data there
Greetz -
You don't lose all the data on the drive if you run a convert, only if you reformat it.Originally Posted by humbug68
Go to a dos prompt and type
Convert c: /FS:NTFS
assuming it's the C: drive you want to convert and all the data remains intact. if the drives in use it will do it next time windows restarts.
DVD Decrypter to ISO file - missing
By mkr10001 in forum DVD RippingReplies: 4Last Post: 5th Jan 2011, 18:55 -
Missing video part in .avi file
By CoMuNisTa in forum Newbie / General discussionsReplies: 8Last Post: 21st Jun 2010, 14:08 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum Capturing and VCRReplies: 5Last Post: 2nd Feb 2009, 16:50 -
two part film wont play ?
By lou41888 in forum Authoring (DVD)Replies: 4Last Post: 31st Dec 2008, 21:49 -
2 DVDs of same film run different lengths but no missing scenes
By headless chicken in forum MacReplies: 2Last Post: 27th Sep 2007, 19:20
