I am capturing from my DV cam (sony) using firewire card (IBM) by using Adobe Premier. The problem I have is that that avi file that gets generated is not very "smooth". It is kind of shaky. The original DV is very smooth but the avi seems to be like "slow motion"....
Any idea why this can be happening and how can i avoid it. Thanks.
You are probably seeing the efects of interlacing during playback on your PC. What pgm are you using to play it back, Windows Media Player?
One way to correct that (and reduce the files size) is to encode it to Mpeg (and de-interlace if you only want to view it on PC). Use TMPGEnc.
Good bitrate to encode a DV file captured from a VHS tape to h264 mp4?
By incubuscsg in forum Video ConversionReplies: 2Last Post: 4th Nov 2010, 16:30 -
Captured AVI file too large
By drgt in forum Newbie / General discussionsReplies: 38Last Post: 29th Sep 2010, 07:22 -
Cleaning Up Captured AVI
By Candoo in forum Newbie / General discussionsReplies: 3Last Post: 17th Dec 2008, 13:29 -
Ive captured a good lossless AVI file, now what!
By Darkstraw in forum Video ConversionReplies: 3Last Post: 12th Aug 2008, 00:10 -
when captured avi goes over 4 gigs nothing recognizes it ?
By 99teggsr in forum Capturing and VCRReplies: 11Last Post: 28th Dec 2007, 22:00
