I was curious? When I'm done encoding my mpeg2 files I just open vcdeasy and add the files and begin burning. I've noticed a lot of people using vcdeasy or something to create a bin or cue file and them burning that to the cd-r. Should I be doing something like instead of the way I'm doing it now.
Thx,
Ryan
only reason to do that is if you want to make chapters.
Is it supposed to look like that? -
@ ch0g0nda: ???
@ Wackyd:
VCDEasy actually makes the CUE/BIN file first and then can optionally burn that (automatically if it set it to) to CD-R with CDRDAO. What you are doing is in fact no different from anyone else.
Some people don't use VCDEasy to burn the CUE/BIN image because (1) they can't get CDRDAO to work or (2) they prefer a different CUE/BIN burning proggy (e.g., CDRWin).
Regards.Michael Tam
w: Morsels of Evidence
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
