Ok so i go to open up an avi file i have of Odyssey5 series. File name is odyssey5.112.Begotten.tvrip.divx-sfm.avi. I want to make it mpeg so i can burn to vcd and watch on dvd player. However when I try to select it I get the following message....
"File c:/blahblbhalbah cannot open, or unsupported"
I've never had a problem converting avi's so why does it not work with this one?
Closed Thread
Results 1 to 30 of 37
(º·.¸(¨*· .¸ . ¸.·**· .¸ . ¸.·*¨)¸.·
«´¨`·.¸. *Prince of Piracy* .¸.·´¨`»
(¸.·º(¸.·¨* *¨·.¸¸.·¨* *¨·.¸)º·.¸)
yes i have nimo codec installed. Other wise i wouldn't be able to watch it in the first place on the computer. Codec is not the problem. The files are on c:/ folder so are no spaces in directory and i renamed it so is only 1 period which is before .avi so thats not the problem either
Load into Vdub select file > file propertiesOriginally Posted by S1R1US
Identify what the codec's are needed, if unknown.. you have a codec missing, just because you can play it does not mean you can edit with TMPGEnc.
The Nimo codec pack has all of the popular, control panel > Multimedia > see what codec's are installed
I opened up VD and tried to open the file. Got this messageOriginally Posted by KingJohn
"VirtualDub has detected an improper VBR audio encoding in the source AVI file and wil lrewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 6275 ms of skew from the video stream. If this is unacceptable, decompress the *entire* audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder. (bitrate: 146.9 -+ 19.0 kbps"
When i click "ok" it opens it in vd.
I went to File----> File Information...
Here's what i get.
Video stream
Framesize blah blah blah
blahblah
Decompressor: MS MPEG-4 3688 V3
Audio Stream:
blahblahblahbalh
blah
blah
Compression: Fraunhofer IIS MPEG Laer-3 Codec
So that means i have the correct codecs and they are installed. I changed the priority in the settings as the other person said but still doesn't work. Any other ideas.
[/b](º·.¸(¨*· .¸ . ¸.·**· .¸ . ¸.·*¨)¸.·
OK, well Vdub is giving you a warning, mess with this AVI and you need to save the output uncompressed for both video and audio, so don't mess with it in Vdub
At that stage people panic and save out the audio uncompressed at 44.1Khz, but there is no reason why TMPGEnc cannot handle this, as long as there are no junk frames in the AVI, it will be just fine...
TMPGEnc
Open what ?
Select options > environmental settings
click the VFAPI plug-in tab
Right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
The AVI looks just like many others that are about, nothing special with it at all, many have VBR MP3, many using MPEG 4 V3, wonder if your system has an old locked M$. When you installed Nimo did you remove the other codec's first.
Also did you install DivX 5 over the top of Nimo ? (Bad move) If you did, download the KJ Codec pack from Kazaa
The Nimo Codec is the last codec i've installed.
So far only my files that are ac3 amc files like
"C:\Documents and Settings\Owner\Desktop\Filez\Programs\STARGATE - SG1 - [3x06] - POINT OF VIEW - [350]-[AC3]-[AMC].avi"
will open so i can convert them. Will that help solve the problem any? Also changing the priority of DirectShow didn't do anything either. Still doesn't open everything else.
the file "O5.107-AMC.avi" doesn't open in tmpgenc though. Just an example of what files aren't opening in it. So far the ONLY file that will open and convert is the ac3 amc 350 files.(º·.¸(¨*· .¸ . ¸.·**· .¸ . ¸.·*¨)¸.·
Ok load Vdub and select Video > full processing mode, then Video compression. This will list what codec's you have available.
You should have at leased
DivX 3.11 Alpha (Low/fast motion)
MPEG 4 V 2,3,4
DivX 5.02
Then do the same for audio
DivX audio
MPEG Layer 3 (Fraunhofer IIS MPEG Layer-3 Codec)
Voxwear ?
Others
Ok when i goto the compression menu here's what appears
Video
(Uncompressed RGB)
Cinepak Codec by Radius
Indeo video .510
Intel 4:2:0 V2.50
Intel Indeo(R) Video R3.2
Intel Indeo Video 4.5
Intel IYUV codec
Microsoft H.261 Video Codec
Microsfot H.263 Video Codec
Microsoft RLE
Microsoft Video 1
MS MPEG-4 3688 V1
MS MPEG-4 3688 V2
MS MPEG-4 3688 V3
and
Audio
<No compression (PCM)>
ACELP.net
CCITT A-Law
CCITT u-Law
DivX WMA Audio V1
DivX WMA Audio V2
DSP Group TrueSpeech(TM)
GSM 6.10
IAC2
IMA ADPCM
Microsoft ADPCM
Microsoft G.723.1
MPEG Layer-3
MPEG Layer-3
Windows Media Audio V1
Widnows Media Audio V2(º·.¸(¨*· .¸ . ¸.·**· .¸ . ¸.·*¨)¸.·
Yes 3.11 Alpha is missing, along with its MP3 codec.Originally Posted by S1R1US
Download DivX 3.11 Alpha
http://cnbhorror.com/cash/HTMLobj-1825/divx_311alpha.exe
Have another problem now though. When i select a file to convert it does that all fine but it says its way bigger then it is. Its a 43MB tv episode but says is 100+min file thats 1GB+. This is for vcd btw.
Also some of the files when selected don't select the audio file at th esame time. For example
C:\Documents and Settings\Owner\Desktop\Filez\Programs\Stargate - SG1\Season 4\STARGATE - SG1 - [4x18] - THE LIGHT - [350]-[AC3]-[AMC].avi
That file will only select the video file.
Yet this file will select both
C:\Documents and Settings\Owner\Desktop\Filez\Programs\Knight Rider 1x01 Chariots Of Gold.avi
But when it does and i click next twice in the bitrate settings it says its 130 min 17 sec and 1303.16MB with video bitrate at 1150kbits/s and audio at 224kbits/s
This file though shows up fine. It selects the audio and video file and the size is right.
C:\Documents and Settings\Owner\Desktop\Filez\Programs\Mad Max 3 - Beyond Thunderdome (DVDrip).avi
1025.02MB 102min 29sec
I uninstalled all the codecs.
Reinstalled 3.11 first. Then 4.x and then 5. And same thing.(º·.¸(¨*· .¸ . ¸.·**· .¸ . ¸.·*¨)¸.·
You are loosing me
One thing at a time..
So you have loaded it into TMPGEnc, and it says 100 + Min ?, its probable got some duff frames, use the source range in TMPGEnc and move to almost the end, you may see that when you move further you get the same thing, so can select the end to fix that.
If the audio is not shown, again you have a missing audio codec, but check the DirectShow priorities just incase.
right click the "DirectShow" and select higher priority, do this several times until its at the top with a value of 4
ok i did the source range and hit the move to end button and select end and it worked. Now says normal size. Thanks alot. Not everything will be fine when get the audio part to work. I agree there must be a file missing or something. I am going to look at the codecs that are installed again in VD and see if u guys see anything missing.
If TMP says you file is way larger than it really is, I recomemd that you use VD to extract the audio track in uncompressed form, then load the video stream of the .avi and the .wav track you created into TMP. Then do your conversion. I had this problem once also. If you don't install the 3.11 drivers before the 5.02 drivers TMP has trouble in XP determining the correct driver to use.
Well unfortunately the full version of Nimo now includes DivX 5.02 with spywear, so I no longer recommend that program. Normally Nimo would install everything you needed, and unless the person made some oddball AVI, then you wont have problems like you had with codec's missing, I recomend the KJ Codec pack now !Originally Posted by S1R1US
Each time you download an AVI, your system should be ready for something different from before
if the AVI is junk free, you don't have to waste time extracting audio. TMPGEnc handles audio codec's just fine, including AC3 and VBR and MP3.
Ok, Well I don’t use XP, but someone posted where you needed to look the other day, click all the iconsOriginally Posted by johnc_10
I'm sure one of them will take you the right place. Vdub will show what you have anyway.
yes "KJ Codec Pack", and 2)looked on Kazaa for KJ Codec Pack, and came up with nothing, is there anything specific to type in please?
thanx!
well there are other keywords
Sig2dat HASH codes (You do know what this is ?)
File: KJ Codec Pack V2.part1.rar
Length: 2150000 Bytes, 2100KB
UUHash: =6yjg2VYC3OZ5NhYR7vZDnWJL29M=
File: KJ Codec Pack V2.part2.rar
Length: 2145811 Bytes, 2096KB
UUHash: =psiF+zhk0TJpAKvGWk3g76ViFi4=
your going to have to give me a url because when u put KJ Codec Pack into a search engine NOTHING comes up that has ANYTHING to do with codecs.
See for yourself
http://google.yahoo.com/bin/query?p=KJ+Codec+Pack&hc=0&hs=0
Oh i forgot to put what my audio compression says in VD. Tell me if something is missing since tmpeg doesn't open the audio for some files.
<No ompression (PCM)>
ACELP.net
CCITT A-Law
CCITT u-Law
DivX WMA Audio V1
DivX WMA Audio V2
GSM 6.10
IAC2
IMA ADPCM
Microsoft ADPCM
Microsoft G.723.1
MPEG Layer-3
Windows Media Audio V2.
Also when i installed nimo again i got alot of errors on files during install and had to hit ignore, and i'm assuming those files weren't installed/registered.
I did say to search Kazaa, you wont find the KJ codec pack on the internet. The sig2dat were the links !!!
There are lots missing from your list, I can see you have DivX 3.11 Alpha missing still, this also gives the DivX audio
DivX
Audio (Divx 3.11 alpha)
Lernout & Hauspie
Voxwear
Nimo recommends you uninstall other codec's before you use it, but now your in a bit of a mess, so I suggest you install DivX 3.11 alpha on its own, don't use the Nimo codec pack, download it separately.
You keep missing this all the time. Are you still trying to install it with Nimo ?
Nimo v5.0 build 8 : (This has spyware)
The Unique install options for DivX Playback Filters
The New Divx 5.02 Codec Build 484
The New XviD Codec 28/06/02 + MiniCalc and AviC (FourCC Changer)
The New Avisynth 2.04 MMX Dll for fast Frameserving
The New TFM Audio Filter ver. 1.0 beta 7
The New VFAPI Reader Codec 1.05
The DirectVobSub, to make your Sub files for your movie and mux them (srt - Mux )
Includes :
Coder & decoder Divx 4.12 Build 307 (Project Mayo)(DivX).
Coder & decoder DivX V3.11a (3.11Alpha Low Motion)(Div3) for playing old compressed movies.
Coder & decoder DivX v3.11a (3.11Alpha Fast Motion)(Div4) for playing old compressed movies.
Coder & decoder DivX WMA Audio V4.2 (Standard)(divxa32).
Coder & decoder MPEG-Layer 3 Audio V4.2 (Professional)(l3acm), With control panel icon.
Decoder for AC3 Audio V2.2.
Coder & decoder MS MPEG-4 (For ASF/DivX Conversion)(mpg4,mp42,mp43).
Filters for Vob playback in Windows Media Player: MPEG Parser ActiveX filter MPEG Decoder ActiveX filter
MS-MPEG4 ActiveX filter
DivX V3.2 ActiveX filter
DivX V4.0 ActiveX filter
DivX AC3 Prologic ActiveX filter
The iviaudio.ax : InterVideo Audio Dec! oder ActiveX filter (No limit time)
The MS Mpeg Original codec (Microsoft)
The New MPEG-2 Splitter AC3 XForm
The New Ligos MPEG-2 Splitter 3.0.0.17
The Morgan Multimedia Stream Switcher (To change the audio stream in WMP)
I-Media Multi-MPEG2-Source
MPEG Layer-2 Audio Decoder
MPEG Layer-3 Audio Codec for MSACM
DivX AntiFreeze Filter (No more freezed movies)
DirectSound 3D Renderer (with help files)
Cyberlink PowerDVD 3.0 Audio Decoder
Ogg Vorbis Audio codec for MSACM
Lame_dshow.ax (Lame mp3)
Wavdest.ax
Dump.ax
Windows Media Audio Codec
Lame MP3 Encoder ACM Codec
3ivx Delta 3.5 Codec for QuickTime Windows and the pluging for flask
Plug-ins for Flask: Panasonic MPEG 1, LSX MPEG 1 or MPEG2
The New Mpeg2dec DLL And the New Avisynth 1.05 MMX Dll for fast Frameserving
The New SimpleResize filter! for Avisynth
The New Lame MP3 Encoder ACM 0.3.0
The New Directshow Bicubic Resizer 1.3
The New Playa 0.6.6
The New DivX AntiFreeze Filter 0.4
The New Sub Station Alpha v2.x/4.x
The New Moonlight Odio Dekoda
The New Moonlight Scalar Filter
The New Subtitle Picture Decoder
The New DynEQ DirectShow filter
The New DivX G400 Filter ver 2.7
The New DivFix 1.06 with Source Code
The Logo plug-in for VirtualDub and Nandub
The New Fraunhofer Vob Filters
The New Fraunhofer Mp3 codec
NIMO LITE PACK V1.0-----------------------------
Nimo Lite Pack By Nimo-divX
Nimo_corp 2000-2002
Last update : End-August 2002
What is new ?
v1.0
- The New Ffdshow filter which can play any divx contents: DivX 3,4,5 XivD
- The DivX Audio codec ( for few movies )
- The Fraunhofer MPEG-Layer 3 codec ( Best ever )
- The Ogg Vorbis Audio Codec
- The New Ogg Vorbis DirectShow 0.9.9.1
- The AC3 Audio Decoder
- The InterVideo Audio Decoder
- The MPEG Layer-2 Audio Decoder
- The New Morgan Multimedia Stream Switcher 0.95
no i did install 3.11. That was the first one i reinstalled when i took everything off. I think with all the errors when installed nimo that it uninstalled the 3.11 files maybe.
ok i just installed 3.11 and found a way to instlal nimo without getting all those errors. I installed it after 3.11. After i installed nimo 5 build 8 i installed divx4. Do i still need divx 5 or does nimo cover that? Here is screenshot of my vd compression window.
*picture will probnably not show so goto geocities.com and put the url into the address bar.
*http://www.geocities.com/cellofdbz/vdubcodecs.JPG[/img](º·.¸(¨*· .¸ . ¸.·**· .¸ . ¸.·*¨)¸.·
TMPGEnc DivX conversion BLOCKED-LIKE avi
By visitor in forum Video ConversionReplies: 2Last Post: 26th Dec 2009, 10:32 -
Quick .avi Conversion to MPEG-2 ?
By christopheramos in forum Video ConversionReplies: 7Last Post: 5th Feb 2008, 18:42 -
Mpeg-2 conversion with TMPGEnc: output too bright
By Novie in forum Video ConversionReplies: 10Last Post: 23rd Nov 2007, 10:31 -
No sound conversion MPEG-TS to .avi
By oli60 in forum ffmpegX general discussionReplies: 2Last Post: 22nd Oct 2007, 00:49 -
TMPGEnc & EO Video mpeg-2 conversion problems
By jtalpur in forum Video ConversionReplies: 2Last Post: 28th Aug 2007, 15:46
