I have an Mpeg that is a non-stardard aspect ratio. So, I decided to reconvert it to ntsc (as it was a 29.97 fps) so it would play in my dvd player. the bitrate of the mpeg was actually quite low about 850 so i decided to max out an 80 min cd with a little higher bitrate. so, i made it 985 with adudio of 128 using those stats, that mpeg (it runs for just under 95 minutes) SHOULD fit on a 80 min with 10 megs to spare. but it ended up over 950 megs! WHY?!?! i used the calculator on this site to determine that max size for the file length - what did i do wrong?
ok so this gets wierder
i just cut the mpeg to make it fit on 2 cds and surprise - the file lost 100 megs somewhere and now fits properly on one cd - what the hell is going on!?!?!?!?
What is the best Bitrate Calculator ?
By Simmons in forum Video ConversionReplies: 6Last Post: 15th Jan 2011, 08:08 -
File Size & Video Bitrate Calculator
By wiseant in forum Video ConversionReplies: 3Last Post: 27th Nov 2009, 21:59 -
bitrate calculator for multiple audio?
By ecc in forum Video ConversionReplies: 4Last Post: 4th Sep 2008, 20:25 -
bitrate calculator
By pcb in forum Newbie / General discussionsReplies: 9Last Post: 1st May 2008, 11:34 -
Real media Bitrate calculator?
By ViB in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2007, 13:34
