I am trying to copy DVD's that I have already made with MyDVD and that currently work in my stand alone player to another DVD. To do this I copy all of the files off of the DVD to a temp folder and then copy them on to a new DVD-R in exactly the same way with the same disc name using EZCD Creator V5 Platinum. The problem is that these discs are not readable by my stand alone player anymore although they are valid on my computer.
I know that you're probably going to tell me to get Nero (I don't want to pay for it just to copy stupid DVD-R's). Is there any way to do this with EZCD Creator that will work properly? Has anyone been able to do this? I would LOVE to hear back from someone with any feedback at all!
Matthew
Use DVD Decrypter...it's free
Just have it create an ISO image of the original and then use it to burn that image to your new DVD-R.
and never use NERO FOR DVD BURNING..... its stinks.... it cause a LOT of players not to play your dvd-r..... use primo dvd.... thats the best..... then u dont have to chge it to a iso just to burn it
Are you checking what mode 1 or 2 that the disk is being made by?
Mode 2 works the best for me when I burn DVD's 3 for 3 players. -
To mol3000:
Have you tried the latest version of Nero (5.5.9.9)?
They seem to have improved the compatibility of DVD movie burning.RealaT Bytes, but that's what life is. -
mol3000: nero is fine for dvd burning, why do a few people moan about it? i do all of mine in nero and they work in about 4 seperate dvd players, people must be burning in the wrong mode/filesystem
using Nero's latest upgrade makes the burning process simple. I like using the new Nero Express (in the new Nero). You can't screw it up that way.
Can't play homemade DVD copies on player
By poz3614 in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2010, 06:26 -
Region Free DVD-R Copies
By Live2WinForever in forum DVD RippingReplies: 7Last Post: 22nd Mar 2010, 14:18 -
LG LHB953 not playing burned copies of my DVD's
By SMaldo in forum DVD RippingReplies: 8Last Post: 3rd Jan 2010, 21:43 -
Organising DVD copies on external HD?
By terrypin in forum Newbie / General discussionsReplies: 5Last Post: 1st Feb 2009, 08:43 -
DVD copies
By JimboS in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 22:33
