Hi I have Pioner DV 505 , i make one VCD with Nero but it cant play on my DVD player . I burn it on CD-RW .. The DVD read but dont show . I only see one blue screen ..
Please Help-me
Thanks,
Luciano
Make sure your player can read CDRs and CDRWs, not all players can. And then make sure it can play VCDs. Just because it says it can play them doesnt mean all that much because what "VCD Compatible" means is that it can play commercial ones that are pressed like CDs or DVDs, not neccessarily burned ones. It means it understand the VCD format not that it will understann any media(disc) that they format is on.
Luciano
I am in the same boat and thought I might add my proplems also, to save time and effort on a new thread
Using Pinnicale studio 7 I created an MPEG using the default VCD settings
I then drag and drop this MPEG file using NERO into Video CD window and burn.
But nothing on a; CDR, CD RW compatable DVD player.
Are there known bugs;
with Nero 4.0.7.1? or Pinnicale studio 7
Sorry if I've stepped on your toes Luciano
Trying is the first step to failure - Homer -
Hi welcome to the forum!
Your dvd should be able to play VCD with CDRW alright (you can check complatible here http://www.vcdhelp.com/dvdplayers.php). So How did you burn VCD with NERO? What version is it? Can you try to burn VCD with something else like VCDImager to create bin/cue file? Oh have you ever try to play this brand of CDRW with your player? You can try to burn audio cd into this cdrw brand and play in your player. -
GuestNERO 4.0.7.1???!!!!! Try updating it to 5.5.9.0Originally Posted by Jimbo Juggs
http://www.ahead.de/ -
Mr./ Mrs. Juggs:
There is a very active Pinnacle Forum which can be accessed at the link below.
http://webboard.pinnaclesys.com/read_forums.asp?WebboardID=1&ForumID=247&SectionID=58&lng=1 -
Wowww Now i see VCD on MY DVD PLAYER
I convert avi to mpeg with TMPGenc.
And with VCDeasy i create cue image and with NERO i burn CD from Image file.. It is very Easy
Now Im Happy !!
So i use VCD.1.1 becouse my dvd player is old model.
:P
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
Codec missing. Dont know which one. VLC wont play either.
By UmmAddan in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2009, 16:48 -
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 06:14 -
Windows Media Player dont play mpeg2
By mogoyon in forum Software PlayingReplies: 4Last Post: 14th Jan 2009, 14:31 -
Last 20-15minutes dont play Properly!
By Ace-Of-Spades in forum Authoring (DVD)Replies: 7Last Post: 5th Nov 2007, 12:22
