  1. My pioneer drive is region free, i have dvd genie.. It used to work fine then suddenly didn't. Ive been stuck on R1 for a while now and its starting to get on my nerves as i once was region free. It must be all down to windows XP... Anyone know how i can disable its region check thing?
  2. First you need DVD genie 4.10, Then make sure "force internal region code" is checked. that should sort it
