I've downloaded some AVI files that wont play using Real One, or any other player i try
says that problem with filter,....
what does this mean, and how can it be corrected ?
thanks.
cant be loaded in vdub
says,
couldnt locate decompressor for format 'dx50'
" vdub requires a video for windows (VFW) compatible codec, to decompress video
direct show codecs not suitable"
for your info, movie concerned is the eminem movie - 8 Mile
cheers, TKnocker -
Go to the Tools section at left, look up Nimo Codec, and download and install from the link.
Hello.
Samsung PC Studio 3 and Windows unable to play mpg files
By gstewart in forum Newbie / General discussionsReplies: 0Last Post: 9th May 2010, 20:06 -
Unable to play MPEG-4 files
By rama_m in forum Software PlayingReplies: 10Last Post: 22nd Aug 2009, 09:12 -
Unable to play avi files
By jayee in forum Newbie / General discussionsReplies: 1Last Post: 20th Aug 2009, 07:45 -
Unable to play SOME MKV files on PCH-A110
By gonzalu in forum Media Center PC / MediaCentersReplies: 3Last Post: 23rd Mar 2009, 00:18 -
What do you use when WMP unable to play *.WMV, *.AVI.
By pwangdel in forum RestorationReplies: 2Last Post: 5th Mar 2008, 20:52
