  1. Member wulf109's Avatar
    Jul 2002
    When I use Smartripper in stream mode I select the video stream and one audio stream. I then select demux to separate file,if I then highlight the video stream it rips the video as an .m2v and the audio as a .vob. I rename the vob to ac3 since it is the ac3 audio stream. Then I load the m2v and ac3 into Tmpeg and encode. The audio is always out of synch. I know there's an option in source range to correct the synch but I've never been able to get satisfactory result.
    I set Smartripper in stream mode but instead of highlighting the video stream I highlighted the audio stream. Smartripper then created a video stream with a vob extension and the audio file with an ac3 extension. Then I loaded that vob and ac3 into Tmpeg and encoded and the audio was in synch!
    Can highlighting the audio stream in Smartripper really solve the audio synch problem?
  2. IF you look at the top right side of smartripper when it is ripping, you will see a box named "AV-Delay", this is the amount it will be out of sync.
    you'll have to use a program like BeSplit to fix that up for you.
    OR
    you could rip the streams to a normal vob, and not demux them, then use DVD to AVI to decode the audio. cos DVD2AVI automaticly fixes this sync problem.
    DVD to VCD made eazy
    http://www.eazyvcd.tk
