I was just wondering what the optimum RAM is needed to capture from analog to digital.
I am using a DVC80 (Dazzle) to connect my Hi8 camcorder to my HP 5440 notebook (P3 850Mhz, 256RAM, 20Gig, Win2K) and the capture software I'm using is Pinnacle Studio 7...everything seems to work great, even during capture (no frames dropped), however, when I play back the .AVI file, I notice that at regular intervals, it seems that there is a quick pause (?)...as if a frame has been dropped...
I guess my question is, why is this so, as even during capture, I notice no frames being dropped...and is my RAM adequate for such a task? thanks...
Capturing, and even more so, encoding is almost 100 % CPU driven. You should have no problem with your set-up, that is backed up, and shown by no dropped frames. Obviously prior to encoding or capping, shut down all un needed services and programs and you should be AOK
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
thanks for the reply spidey. i was just wondering if recording stuff on my Hi8 tape in LP plays a part in my "problem"...
Gigabyte Mobo, Input/opinions needed... & a Q on ram for new build.
By Noahtuck in forum ComputerReplies: 12Last Post: 28th Aug 2011, 07:30 -
Value ram
By jollyjohn in forum ComputerReplies: 19Last Post: 5th Mar 2011, 06:21 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30 -
more ram?
By Heywould3 in forum ComputerReplies: 7Last Post: 24th Jul 2007, 11:32
