  1. Hi:
    Dumb question but....
    It is possible to burn a VCD or SVCD in a CDRW disk in the same way you do it with a CDR disk using Easy CD Creator or Nero, and then erase the data and use the same disk to burn another video or movie.
    I allways believed that you only could erase information from a CDRW disk if you format the disk using a software like Dirct CD.
    Thanks for any advise regarding this matter
    THX
    8)
    Rey
    Upstate NY
    CD-RW's can be erased no matter what the format.
    Mar 2002
    chicago
    in order to erase a CDRW in Nero, go to recorder, erase rewritable media.
    be careful though...I've been having problems with my Memorex CDRW's not being able to write to them after using Nero to erase...Clone CD, however, works perfectly. It may just be the discs...I've had a lot of problems with these. I'll never buy their discs again.
    what are you askin' me for...
    I'm an idiot!
