I am trying to export my finished product from Premiere (6.0) using the CCE encoder plugin. For some reason CCE sets the output to 1 frame/sec and premiere gives an error if I try to export anyway... I don't have the $$ to buy the new version of Premiere, but I want to be able to export my movies in a DVD compatible MPEG2 format. Has anyone experienced this problem before? Thanks for any help.
Buttwidget
Oh, one more thing too... I would like to export the material from Premiere in a format that DVD Maestro can handle. For some reason it won't accept avi, mpg1 or mpg2 files that programs like sonc dvdit or spruceup will... Any help here? Thanks in advance.
Buttwidget -
for your second question - you will need to de-mux the mpeg program stream to seperate audio and video streams. Maestro will not accept a mpeg audio only - you need to add a ac3 or pcm stream also ..
Exporting HDV with Premiere Pro 2
By HDVth in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 9th Mar 2011, 14:41 -
exporting from premiere: progressive or interlaced ?
By codemaster in forum EditingReplies: 12Last Post: 5th Jan 2011, 00:57 -
Premiere CS4 lossless exporting
By timwizard in forum EditingReplies: 7Last Post: 16th Feb 2010, 09:49 -
When exporting out of Premiere...
By bsuska in forum Video ConversionReplies: 20Last Post: 4th Jan 2010, 17:22 -
Render before Exporting in Premiere Pro
By newsphotog in forum EditingReplies: 1Last Post: 29th Sep 2009, 10:39
