Hi, I recently captured a movie on my hard disk using VIRTUAL DUB. I checked SEGMENTED AVI, and I used a Huffyuv compression. I used a low compression to keep the best quality. The result is a file 11.5 GB divided into 6 AVI FILES.
Now I have a trouble. I want to encode these files to create a SVCD, but I'd like to create a ONLY-FILE for 2 reasons:
1- The 2 pass VBR will give me more quality using long videos, instead of small videos.
2- I need 1 MPG to burn so the video will play seam-less on my Standalone DVD player (since if I create a multitrack SVCD there will be a pause between tracks).
I know that Virtual Dub can FRAMESERVE. So, I tried to frameserve the entire file, so I could encode it using TMPGENC (that supports VDR files) but TMPGENC didn't go. It said the VDR file is not valid ...
so, does anybody know how to frameserve correctly using Vdub?
Since you have already encoded your 6 files into one huge file, why not forget about frameserving and just go ahead and load the single file into TMPGEnc?
Hello. -
No, I didn't. I haven't created a 11.5 GB file (the max size for a file with FAT32 is 4GB). I have 6 2GB files that if opened with VDUB, will be treated like a unique file, while if opened 1with TMPGENC or other progs, are treated like 2 GB files ... understood?
I think that the only way to encode the 6 files at once is frameserve with VDUB (I know that vdub frameserving files are supported by TMPGENC but on my system it didn't go) -
Are your Nimo Codec Pack loaded, and is Direct Show in TMPGEnc has a priority of at least two?
Hello.
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
Can't convert avi to vcd, svcd etc...Failed Message
By shankbone in forum ffmpegX general discussionReplies: 2Last Post: 10th Oct 2009, 02:12 -
Batch convert DV-AVI to MPEG2
By w@ntonsoup in forum Video ConversionReplies: 3Last Post: 27th Sep 2009, 16:08 -
VirtualDub: Saving Segmented Avi
By Ruro Jiruries in forum EditingReplies: 0Last Post: 18th Jun 2009, 08:13 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
